4L80e Temp Sensor
Old Aug 19, 2013 | 08:48 AM
Shownomercy's Avatar
Man-Crush Warning
Default 4L80e Temp Sensor
If I toss my gauge sender in the pressure port, how off will that reading be?
Old Aug 19, 2013 | 04:32 PM
DietCoke's Avatar
Mine reads within 2% of the internal trans sensor verified by my optishift logs. Good enough for me
Old Aug 20, 2013 | 12:29 PM
Burken01's Avatar
10 degrees off on the pressure port vs a temp sender in the pan.. From what I've seen..
I hear the pressure port is bad since its threaded into the case and the temp sensor will read the case temp more than the fluid itself..
Old Aug 20, 2013 | 01:03 PM
DietCoke's Avatar
By that same logic the temp sensor will read the pan metal temp more then the fluid itself too.
Old Aug 20, 2013 | 08:41 PM
Burken01's Avatar
not true, the pan metal is 1/8'' thick and the sender protrudes further into the pan vs the pressure port..
Old Aug 22, 2013 | 11:46 AM
Man-Crush Warning
I am gonna toss it in the pressure port then compare to HPtuners and OEM sensor readings.
Just want a ballpark to make sure I am not cooking the trans, unsure on if cooler is up to it.
