4L60 no second and no fourth
Old Sep 22, 2013 | 05:52 AM
bodies67's Avatar
Default 4L60 no second and no fourth
My 4L60 is skipping 2nd and has no 4th. Some one told me it my be the accumulator and servo. I have no Idea? Can anyone help me? Man I don't want to pull it out. The Trans only has 26000 miles on it. They said I should only be able to push the cover in a 1/16 to a 1/8. Mine will push in a 1/4, Could it be the orings or the shaft? Thank's Bodie
Old Sep 22, 2013 | 08:10 AM
Vince B's Avatar
Moderator
Sounds like a broken or extremely worn band IMO. With being able to push the cover in that far obviously you have a situation with to much travel of the servo assembly.
Old Sep 22, 2013 | 10:05 AM
mrvedit's Avatar
Moderator
While Vince is absolutely correct, several members here were able to "patch" their servo and get more mileage out of their transmissions. You don't need to remove the trans to remove the servo, although on a Camaro you likely need to lower the rear of the trans a bit. Here are the threads:
https://ls1tech.com/forums/automatic...-gear-all.html
https://ls1tech.com/forums/automatic...t-trouble.html
(You can skip the OP's initial 1500-word long description.)
If you are not comfortable welding, a local trans shop might be able to do this for you. I learned this "trick" from a local trans shop mechanic.
Obviously this assumes the band is only worn; if it is broken you will need to remove and rebuild the trans.
Old Sep 22, 2013 | 10:20 AM
billybatty's Avatar
Got reverse? if not,possibly busted sunshell.
Old Sep 22, 2013 | 10:22 AM
mrvedit's Avatar
Moderator
Good point! I assumed 2nd was slipping.
Old Sep 23, 2013 | 10:00 AM
performabuilt's Avatar
LS1Tech Sponsor
I would agree provided there is reverse its a band issue slipping liner burned or missing or broken lug or tab.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
