4L80 running hot
Old Sep 29, 2013 | 10:40 AM
brizzle815's Avatar
Default 4L80 running hot
00 silverado ls1 swap with 3600 stall 4l80e 4.10 gear
trans runs about 205 to 225.
Notice that on highway temps go up slowly until 215 to 225.
Then getting off highway and going threw town trans drop back down 205 to 210.
At first trans cooler lines was plumb radiator then cooler then trans.
Change to just cooler (bypass radiator) and no change.
Cooler is small 8''x12'' or 12''x12'' mounted in front of radiator behind grille. Not sure what brand.
on highway i can shift up to over drive and rpms go down as if going in higher gear like it suppose to. also from drive to 3rd rpms go up as if going down in gear like it suppose to. I can't feel any slipping.
Any help would be greatly appreciated
I thought about looking into trans pan has the fins to try to cool down. I also considering going to a dual cooler set up or 1 big cooler.
I would like to change the aluminum lines to like a stainless steel braded line (don't know if that would help cool it but it sure would look good.
Old Sep 29, 2013 | 01:31 PM
Blackpanther99's Avatar
Sounds like that cooler isnt doing its work. Does it do the samething even when you are just cruising?
Old Oct 1, 2013 | 08:23 AM
brizzle815's Avatar
thinking bout buying this
http://www.ebay.com/itm/321159926753...84.m1423.l2649
i hear everyone using b&m or trucool or supercool 40K.
I haven't ordered yet hoping that more members would chime in.
Do i need to drain all the tranny fluid out? NO idea what kind of fluid is in there. can i just add any trans fluid to it if needed?
thanks
Old Oct 1, 2013 | 08:24 AM
brizzle815's Avatar
Yes highway tends to get hotter.
In town drop 10 dergrees but down to 200 to 210
Old Oct 1, 2013 | 09:21 AM
72blownvert's Avatar
Does the trans have lockup? If it does not lockup at highway speeds that could be a contributing factor to the trans running hot.
Old Oct 1, 2013 | 11:27 PM
brizzle815's Avatar
I was told trans has lookup.
Old Oct 2, 2013 | 07:04 AM
You need to verify with a scan tool to see if lockup is working or not.
Old Oct 2, 2013 | 01:11 PM
brizzle815's Avatar
Were can i get a scan tool?
Or will a local trans shop have the scanner?
or performance shop have a scanner?
thanks
Old Oct 2, 2013 | 01:19 PM
Any good trans shop should have a scanner and be able to verify if it's working properly.
Old Oct 2, 2013 | 01:21 PM
Ferocity02's Avatar
You should be able to feel the lockup during cruise, the RPM will drop a couple hundred RPM.
Go with the 40K cooler. You can find them for around $140, and there is a guy on pt.net that sells brackets for an easy install.
Old Oct 2, 2013 | 03:33 PM
brizzle815's Avatar
So on highway. Cruising I should feel trans lookup and rpms go down around 200 rpms.
I read some where if I tap brake rpms should briefly go up because trans is in lock up. Is this true. I will do some more research but what are some good road rest I can do to diagnose problem little better.
Thanks for the replies
Old Oct 27, 2013 | 10:36 PM
brizzle815's Avatar
so installed the tru cool 40k and ordered brackets from time2kill on this forum.
works great 175 on highway.
165 in town
Took alot longer for trans to get warm. Even at wot i didn't see over 185. Plumb through cooler only.
thanks for all your tips and advice.
I plan on next having some ss braded lines installed.
The brackets from time 2 kill made this install a breeze.
