4l60 to 4l80 swap help
Old Oct 10, 2013 | 06:39 AM
ZAPPAGU's Avatar
Default 4l60 to 4l80 swap help
Hey guys, doing als1 into nissan patrol swap with the 4l80. I've researched and have followed 2 different sets of instructions. The tune is for a 4l60.
The car is 4wd so I have spliced into the nissan one hoping it will tell the ecu what's going on and stop it going into limp mode. The first setup I was told would work was using the relay to invert the signal and removing a pin. The second was introducing the speed sensor the 22 and 23 of the red connector and swapping 79(gw) into the removed 2 pin on the red connector and it still doesn't work.
Any suggestions, do I need both the speed sensors?
Old Oct 10, 2013 | 07:23 PM
joecar's Avatar
You also have to drive the 4L80E TCC PWM signal from the 4L60E TCC On/Off signal (since the 4L60E controller will park TCC PWM at 90% while the TCC is unlocked).
Do you get any DTC's...?
