yep found that out the hard way i guess, after installing a transducer i seen my line pressures were low so i adjusted them where i needed them, getting around 230psi at max
Originally Posted by built408
Cooler line pressure and main line pressure are totally different. Get a good line pressure reading in all gears and at wot. I like to see 230 on a fresh build.
