4L60e transmission question
Old Nov 19, 2013 | 07:40 PM
mrvedit's Avatar
Moderator
Originally Posted by davidc212k
well today after 3 days of driving the car. the mph has stopped working. any suggestions.
I assume you mean the speedometer has stopped working.
The VSS (vehicle speed sensor) is mounted at the back of the trans. Perhaps the connector fell out or the wiring got too close to the exhaust and melted. The trans will not shift correctly without the correct speed being sensed.
Take it back to the trans shop; it is their responsibility.
Old Nov 19, 2013 | 10:10 PM
davidc212k's Avatar
Yea i kinda got that feeling that the trans was not shifting properly. ima take a look at the wire.
Old Nov 19, 2013 | 10:24 PM
davidc212k's Avatar
Yup the connect to the VSS is kinda loose and the green and black wire have some shortage or it seems like the wires have some skin cut off of them.
Old Nov 20, 2013 | 07:15 AM
mjs1012's Avatar
Bad speed sensor?
Old Nov 20, 2013 | 09:01 AM
davidc212k's Avatar
Could be bad sensor or wires. Shop is taking a look at it as I type.
Old Nov 20, 2013 | 10:08 AM
davidc212k's Avatar
They replaced the vss and speedo still doesn't work. They stated at first that its the gauge cluster. I told him it was working before and and after the transmission rebuild. Then I told him that the first gear on the transmission would not kick in so she tested the car by driving it and stated that I was right so they said that the vss may not may not be grabbing any connection the speedometer so I left the transmission at the shop so they can take a look at it in more debt wish me luck
Old Nov 20, 2013 | 10:22 AM
davidc212k's Avatar
Could the shift kit they installed cause this problem?
Old Nov 20, 2013 | 12:22 PM
davidc212k's Avatar
Scanned for codes and we got error code24. Faulty vss or wires or the tps.
Old Nov 20, 2013 | 01:11 PM
mrvedit's Avatar
Moderator
No.
Its got to be the VSS or the wiring. They will figure it out.
Old Nov 20, 2013 | 04:01 PM
davidc212k's Avatar
shops just called and stated its the wiring and its all fixed
Old Nov 20, 2013 | 05:06 PM
davidc212k's Avatar
Thanks everyone for their support.
Old Nov 20, 2013 | 07:39 PM
  #32
mrvedit's Avatar
Moderator
Glad to hear that it is all fixed now.
Old Nov 26, 2013 | 11:16 AM
  #33
davidc212k's Avatar
Last night my father told me a i have a transmission leaking.
So today i looked at it and it seems that i have a leak on the external cooler lines.
This is what they basically did.
This is an image from google search i did.
Mine does not have double clamps. only one. Is there any recommendations on how i can stop the leaking besides tightening the clamp more. obviously pressure is creating this leak.
Old Nov 26, 2013 | 12:12 PM
  #34
mjs1012's Avatar
Tighten the clamp and add another one. Ive had mine like this for a while and as long as its tight there shouldnt be any leaks
Old Nov 26, 2013 | 01:08 PM
  #35
davidc212k's Avatar
thats what i was thinking. will do. thanks.
