TH400 crossmember
Old Dec 1, 2013 | 02:15 PM
BOLO's Avatar
Default TH400 crossmember
Can I use a factory M6 crossmember for a TH400 swap? Or do I need an aftermarket crossmember for this swap? Thank you in advance.
Old Dec 1, 2013 | 11:20 PM
got-a-ls1's Avatar
i have no idea as far as the placement on the mount (have heard it fits but have also heard it didnt haha) but you will need either a short torque arm or to fabricate a torque arm mount somehow
Old Dec 7, 2013 | 03:06 PM
RENE'S RAGE's Avatar
Call Eric @ MWC and he will set you up.
Old Dec 7, 2013 | 03:25 PM
BIGsmokey10's Avatar
Yes you can.
Just curious are you still running your stock bottom end lt1 set up, trying to break 10's?
Old Dec 8, 2013 | 12:41 PM
BOLO's Avatar
Originally Posted by BIGsmokey10
Yes you can.
Cool.
No longer running the ole LT1. A pushrod let go and blew a piston during a dyno session over the Summer. I was going to build a 383 or 396 stroker, but decided to go LSX. Now planning on running a TH400 with the new build.
