02 Firebird Transmission Problems...Need Help!!
Old Dec 9, 2013 | 08:17 PM
Nick Demio's Avatar
Arrow 02 Firebird Transmission Problems...Need Help!!
I just bought a 2002 Pontiac Firebird and im having problems with the transmission. Wanted to get you guys opinion before taking it to a shop. Its a v6 automatic at the moment. The problem is, it takes a little while to shift into 2nd gear when i driving down a side street at regular speed. Sometimes, when im driving it and it does this, if i hit the break a little and then press that gas again, it will shift right into 2nd, but the majority of the time..it will take a while. Im wondering do i need to get the tranny rebuilt, maybe a sensor or something...your help and opinion would be appreciated. Motor has 95, xxx original miles on it. No check engine lights or on or nothing.
Old Dec 9, 2013 | 10:38 PM
mrvedit's Avatar
Moderator
This sounds like the band is slipping, indicating the trans is ready for a rebuild. Here are some similar threads:
https://ls1tech.com/forums/automatic...t-trouble.html
https://ls1tech.com/forums/automatic...-gear-all.html
https://ls1tech.com/forums/automatic...-my-4l60e.html
Note that a few people had luck lengthening the servo pin with a welder, but at best that will only give you a little more time. It is also not trivial to remove/install the servo in your car.
I always recommend first hooking up a trans pressure gauge to make sure line pressure is correct. A trans shop can do this for you. They can also drop the pan and visually inspect the band as a small portion is then visible.
