where would you put your trans cooler?
Old Jan 19, 2014 | 07:02 PM
boostit5.3's Avatar
Default where would you put your trans cooler?
some back story the tci converter in my car decided to show its true colors... it came apart and sent aluminum all through my trans/cooler/etc. now everything is going back together and i've ran into a hurdle, before i didnt have the a/c condenser in the car so i had plenty of room for an external cooler. well ive put the a/c back in and with my cold air intake plenum i dont have any room for the new cooler to go in front of the condenser (its a pretty big hayden). the only place i can think is between the radiator and condenser but i've never done it this way and im not sure if its gonna keep cool enough. im also deleting the stock in radiator transmission cooler because im sure it has some aluminum in it.... i was gonna put it in between the 2 toward the bottom of the passenger side, from the bottom that looks like it gets the most airflow (the CAI sits against the top middle of the condenser then kinda pitches out toward the bottom). thoughts? alternative locations?
Old Jan 19, 2014 | 07:07 PM
JustAFooL's Avatar
Mine is mounted to the front of the radiator, does fine. My temp gauge never rides higher than 180 unless I'm just absolutely flogging on it..
Old Jan 19, 2014 | 07:11 PM
RedDeadG8's Avatar
how big is the cooler?
majority of us auto guys mount it like this:
https://ls1tech.com/forums/automatic...ope-style.html
Old Jan 19, 2014 | 07:40 PM
boostit5.3's Avatar
its 11x11 5/8... i live on a dirt road im a little weary of mounting it like that, but not opposed. ill see how i can fit the new one in there tomorrow. http://shop.advanceautoparts.com/web...mission+cooler
Old Jan 19, 2014 | 07:48 PM
boostit5.3's Avatar
i have a 160 degree t-stat too so might not be so bad in between... if i put it more towards the middle on the passenger side it would be right behind the fan on that side.
Old Jan 19, 2014 | 07:51 PM
boostit5.3's Avatar
this might work if it dont fit in between
Attached Thumbnails where would you put your trans cooler?-transcoolerdopestyle20100523_50-.jpg
Old Jan 19, 2014 | 08:29 PM
jsteele90's Avatar
mine is mounted on my Midwest Chassis chromoly bumper support with a 2400 CFM fan mounted to it.
Old Jan 19, 2014 | 09:49 PM
soundengineer's Avatar
flat against the Radiator with a set of flat top zip ties made to go thru a radiator...
tried and true...works great...no cooling issues
Old Jan 19, 2014 | 11:19 PM
Cajun ELESS-ONE's Avatar
mine was mounted infront of the radiator as well. you know its gonna get air flow even when ur not moving because of the radiator fans
Old Jan 20, 2014 | 09:38 AM
boostit5.3's Avatar
think it would be ok with a condenser in front of it though?
Old Jan 20, 2014 | 09:52 AM
LS-ONE_DAY's Avatar
Mine is tied to the condenser. Haven't noticed any problems. Highest temp I saw was sitting still in 95-100* weather in Summer temp got to like 186
Old Jan 21, 2014 | 08:42 PM
boostit5.3's Avatar
well this is how its goin in... half of it or more is in the direct air path from underneath, the rest is in the bumper and the passenger vent in the front of the bumper blows on one side of it. heres some pics i used a piece of this tray table to make the bracket.
Old Jan 21, 2014 | 10:24 PM
jsteele90's Avatar
so from the looks of it, looks like it is blocking the air to your air lid now. Is that correct? or is it just the way you took the picture?
Old Jan 22, 2014 | 09:03 AM
boostit5.3's Avatar
yeah its just the way i took the picture... its only blocking like 2-3 inches on the one side.
Old Jan 22, 2014 | 09:07 AM
boostit5.3's Avatar
actually i wouldnt say blocking it, i have it slightly slid up under the cai so i could get as much of the fins exposed as i could. it'll prolly just draw a little hot air off it on the one side.
