4l80e shifters for Fbodies
Old Mar 3, 2014 | 09:35 PM
BIGDRAGON's Avatar
I'm interested in one for the 4l80
Old Mar 4, 2014 | 06:07 PM
BIGDRAGON's Avatar
Bump bump
Old Mar 8, 2014 | 02:42 PM
Cam72aro's Avatar
I use the b&m pro stick with the 4 speed gate installed in it.
Old Mar 20, 2014 | 05:43 PM
texastrip6's Avatar
Originally Posted by White.Lightning
Others have hacked their A4 upper console and put in a more 'race' oriented shifter....
does anyone know which shifter this is?
Old Mar 20, 2014 | 06:15 PM
White.Lightning's Avatar
http://www.precisionperformance.com/kwik1.htm
Old Feb 22, 2019 | 07:24 AM
Tpearson66's Avatar
Default M6 to turbo 400
Originally Posted by JustAFooL
They are 65$ shipped and PayPal'ed, Same as quarter stick mount.
do you make a plate and mount for a 02 camaro m6 to a hurst pistol grip quarter stick
Old Aug 2, 2020 | 06:30 PM
1-Sleeper's Avatar
Default M6 to TH400 shifter adapter plate
Did you ever find a way to mount the quarter stick in a m6 car? I'm probably going to get a auto console, but still need to prop it up in front. I think i can use the airbag module front bolts for the back of the shifter plate, which I've started on already. Hopefully that won't be too high
Old Aug 3, 2020 | 02:54 PM
007FJ's Avatar
I mounted mine on the Precision Mount which is why it's higher than the other one shown. Lots of fitting to make it look good. The Ballenger Wide Band is back in the cubby hole and I put a P59 in it that had Flex capable and was 4L80 already. Plus I changed 4L80's out and the transbrake switch is actually for the ramped side of the Boost Controller now.
Old Jan 24, 2024 | 03:56 PM
TheREDZ28's Avatar
Default Do you still make the brackets ?
I just got done building another mount. This one fits the B&M Pro Stick in the factory console. I already have one that fits the Hurst Quarter Stick into the factory console. Hurst quit producing the 4speed shifter so I had to go with another. Hasn't made it to classified section yet, but will in a day or two. This will work with the 60e if you'll drill the cable out and put it on the factory shifter arm. PM me if interested in one.. BTW, they make an adapter for the 80e too.
In neutral position:
Attachment 680197
In park position:
Attachment 680198
In 1st gear:
Attachment 680199
Old Jan 25, 2024 | 10:18 PM
91 Z28's Avatar
Not in a 4th gen car but my 3rd gen. Hurst makes an awesome shifter for 4 speed transmissions
Attached Thumbnails 4l80e shifters for Fbodies-pxl_20230611_005457292.jpg   4l80e shifters for Fbodies-pxl_20230611_005506925.jpg   4l80e shifters for Fbodies-pxl_20230611_005450228.jpg   4l80e shifters for Fbodies-pxl_20230611_005516690.jpg
