Can anyone de-code this 4L60E trans for me?
Old Jan 25, 2014 | 02:35 PM
Alwhite00's Avatar
Default Can anyone de-code this 4L60E trans for me?
Here is the tag on top - The stamp in the bottom looks like 1CJD 1665 282858
Any way to tell if it was a V6 or V8 trans? I am rebuilding it but would like to know.
Thanks
LK
Old Jan 29, 2014 | 10:51 PM
zgp's Avatar
zgp
Thanks
LK
That's from a 2001 2wd pick or van, used behind the 4.8L and 5.3L engine.
Old Jan 30, 2014 | 04:28 AM
Alwhite00's Avatar
Thank you, Much appreciated.
LK
Old Jan 30, 2014 | 09:23 AM
mrvedit's Avatar
Moderator
To be absolutely sure the trans will bolt up to an LS engine, make sure the input shaft looks like this:
Unless someone swapped parts in the past, it will also have the bolt hole in the 12 O'Clock position.
