surging when converter is locked
Old Jan 29, 2014 | 11:14 AM
jimmyp3353's Avatar
Default surging when converter is locked
Just installed a Circle D converter in my G8 GT and I noticed when cruising with my foot on the gas at say 45 with the converter locked the RPM's will jump about 200-300 rpm then come back down every few seconds. It's almost like the torque converter is unlocking then locking quickly. Normal?
Old Jan 29, 2014 | 11:45 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
what does it do at 5-10 mph higher ?
Old Jan 29, 2014 | 12:34 PM
Circle-D_Brian's Avatar
You need to check your desired slip in the tune. Zero this out. If you have any questions give us a call .
-Brian
Old Jan 29, 2014 | 02:16 PM
Screen shot below of HP Tuners. Everything in the yellow box is supposed to be set to 0.
-Brian
Old Jan 29, 2014 | 02:26 PM
jimmyp3353's Avatar
Just talked to the speed shop/tuner and they said that it is very common for the 6L80 6 speed auto to surge a bit with an aggressive stall. Very reputable shop that is a sponsor on a lot of LS sites.
Old Jan 29, 2014 | 02:27 PM
jimmyp3353's Avatar
-Brian
they are 0
Old Jan 29, 2014 | 02:29 PM
jimmyp3353's Avatar
haven't cruised in it over 45mph. Drove the car home from the shop in sub 0 temps yesterday.
Old Jan 29, 2014 | 03:17 PM
That much slip make me nervous. It could damage the clutch/clutches. We have seen the desired slip tables zeroed out and had the car behave otherwise. I would have your tuner monitor actual slip in real time. That will give us a better understanding of what may be going on.
-Brian
Old Jan 29, 2014 | 07:04 PM
jimmyp3353's Avatar
No slipping. Just torque converter locking and unlocking.
Old Feb 7, 2014 | 10:50 AM
JKB315's Avatar
Good thread. My stall is doing the same thing when it locks up. It's annoying . Going to see about getting a better tune.
Old Feb 7, 2014 | 11:20 AM
Circle-D's Avatar
Log it and see if the slip RPM is going up and down, 0-200 range. If so it sounds like the desired slip tables did not flash correctly in the tune. I have seen a few occasion where even though it says the tables are zero, they are not. The fix was a completer re-write with a GM MDI.
Chris
Old Feb 7, 2014 | 09:42 PM
peteggl's Avatar
My 4l60e does the same thing with a PTC 4000 stall anywhere from 45-55 mph but never above or below
