trans temp sender...
Old May 11, 2004 | 09:23 PM
wbw2's Avatar
Default trans temp sender...
hey guys, I just read through all the old posts on this and read quite a few posts about a bolt half way up the tranny that the sender will fit right into.
does anyone have any pics of their install, so I can see it before I start?(the sender, NOT the gauge..) If not, exactly which bolt is it? measurements would be nice if possible
thanx in advance!
Old May 11, 2004 | 09:30 PM
heyitsTaJay's Avatar
thanx in advance!
i read the sme thing. get under your car and look at the tranny on the drivers side. about 4inches up is a bolt just sitting there. it is allll by itslef. there are no belts around. you cant miss it!
the sender will thread in, and dont forget some tape on the threads.
J
Old May 11, 2004 | 09:31 PM
here ya go!
http://www.black98.cz28.com/photo6.html
Old May 12, 2004 | 05:42 AM
wbw2's Avatar
how far back from the edge of the tranny(or bellhousing) is it?
Old May 12, 2004 | 05:52 PM
heres an easy way to spot it. slide under the car from the drivers side. find the pan, and then look up about 4 inches. its a bolt just sitting there. theres nothing connected to it. its just sitting there.
Old May 12, 2004 | 07:30 PM
wbw2's Avatar
thanx, that's what I needed!
Old May 13, 2004 | 07:55 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
It is a pressure port that mechanics can run a gauge to messure line pressure.
SteveC
Old May 13, 2004 | 01:46 PM
01Z0H6's Avatar
You will not get an accurate reading from that spot.
Here is what i did.
Go to Autozone ( similar part store) and get a B&M drain plug kit.
remove your tranny pan & drill a hole 1/2 in. in diameter. Install the adapter to the pan & instead of using the drain plug, place the sender in it. Works Great & you will get a "true" reading of the fluid. JMO!! Good luck.
Old May 13, 2004 | 06:00 PM
cablebandit's Avatar
not a true reading? How so? I put mine there and don't know if it is accurate or not
Old May 13, 2004 | 08:56 PM
01Z0H6's Avatar
Think about it....
Is the fluid running up there?? Consistantly??
What of the volume of fluid?
Now, how bout the pan? Would you say the fluid is consistant @ all times?
Pretty straight forward IMO.
Old May 31, 2004 | 12:51 PM
Danny2tek's Avatar
You drilled the "pan" or your just saying take of the pan and drill the housing?
Old May 31, 2004 | 12:57 PM
i used autotap and the guage is about 10-12 degrees off. i kno how hott it is now since i autotapd it. when mine reads 150 its more like 161.
