stall not locking on dyno
Old Feb 25, 2014 | 06:49 AM
bigantws6's Avatar
Default stall not locking on dyno
Alright guys had my car re dyno again yesterday and the stall converter wouldnt stay locked what the reason for this when i drive stall locks up fine. The stall is a revmax 4k
Old Feb 25, 2014 | 09:27 AM
01ssreda4's Avatar
Stop trying to lock your stall on the dyno. If it wasn't staying locked it was probably slipping and throwing clutch material through your trans. You'll be up for a rebuild soon because of it. Hope it was worth it
Old Feb 25, 2014 | 11:03 AM
bigantws6's Avatar
It wasnt me trying to lock it my tuner was saying. It wont lock and trying to figure if my stall was bad or not
Old Feb 25, 2014 | 11:05 AM
mrvedit's Avatar
Moderator
ONLY triple-disk converters should ever be locked at WOT because the lockup clutch on standard converters cannot reliably hold full power. In the stock tune or any good "mailorder" tune the converter is unlocked at 50% throttle (or even much lower) to protect it.
If you didn't pay $1000+, you don't have a triple disk converter.
Old Feb 25, 2014 | 11:09 AM
mrvedit's Avatar
Moderator
I'm confused, in the first post you say it locks up fine while driving. Under what condition won't it lock up?
With a proper tune, it will not lock up with more that 50% throttle.
Old Feb 25, 2014 | 11:13 AM
bigantws6's Avatar
He said if the converter would lock up i would of made moree power
Old Feb 25, 2014 | 11:16 AM
bigantws6's Avatar
Okay thanks alot mrverdit
Old Feb 25, 2014 | 11:22 AM
thunderstruck507's Avatar
yes, locking the converter will show more power on the dyno but it is bad for the converter
dynos are tools for tuning, the numbers can be manipulated and don't really mean much
Old Feb 25, 2014 | 12:22 PM
bigantws6's Avatar
Okay i knew the auto wont show good number i waa just starting to worry that maybe my stall was going out or something thanks thunder
Old Feb 25, 2014 | 02:16 PM
mrvedit's Avatar
Moderator
I suspect in the old days of barely-300HP engines that a locked converter could handle that power and show a slightly better number on the dyno. But with 500HP+ now being common, a single-disk converter cannot reliably handle that much and dyno operators have not learned that yet.
