LS1 4L60 Flywheel Questions
Old Mar 27, 2014 | 08:48 PM
Bama99z's Avatar
Default LS1 4L60 Flywheel Questions
Trying to gather some information on the factory GM flywheel. Anyone know what horsepower that the are rated or good for?
Old Mar 28, 2014 | 06:12 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Flexplates do not have a horsepower rating !!!
There was a 'design' change during the 99-00 ? years. Prior to that,the flexplate had the large round holes,the change introduced 'peanut shaped' holes and that design has been a failure. The later design when they fail were replaced by the earlier design and GM stock is zero and no longer available.
https://ls1tech.com/forums/automatic...s-b-m-ect.html
https://ls1tech.com/forums/automatic...placement.html
https://ls1tech.com/forums/automatic...flexplate.html
Old Mar 29, 2014 | 07:47 AM
01ssreda4's Avatar
TCI all the way if your budget can afford it. Piece of mind can be priceless sometimes.
