M6 to TH350 reverse lights Help
Old Mar 27, 2014 | 11:35 PM
N2Ojunky's Avatar
Question M6 to TH350 reverse lights Help
What wires or plug controls the reverse lights? I bought my car a 98 camaro Z28 with a m6 to th350 conversion and the reverse lights don't work. I am trying to find out what plug/wires go to "control" the reverse lights. Someone please help, I would love to get them working! Thanks for any help.
Old Mar 29, 2014 | 01:21 PM
turyg ls1's Avatar
Did you ever figure it out? I went from t56 to 4l80e and I have figured out how to get them to work
Old Mar 30, 2014 | 12:45 AM
N2Ojunky's Avatar
No I have not yet. What did you do with yours?
Old Mar 30, 2014 | 08:24 AM
nocooler's Avatar
There is a plug under the car, that plugs into the passenger side of the T56. It has 2 wires.
Splice and connect them to the reverse switch on your shifter.
Old Apr 1, 2014 | 07:24 AM
N2Ojunky's Avatar
Thanks I will try to find it, do you know what colors the wires are?
Old Apr 2, 2014 | 01:42 PM
LPTXZ28's Avatar
you will need to tap into the brown wire and the light green wire on the M6 harness (passenger side) underneath the car. I ran these wires to the switch on my shifter thru a hole in the plate that I mounted my shifter on.
Old Apr 8, 2014 | 08:11 PM
N2Ojunky's Avatar
Thanks. I will order the switch for my shifter from summit.
Old Apr 8, 2014 | 09:02 PM
JustAFooL's Avatar
I'll check mine later, there is a wire that I tapped when I installed my shifter and it worked. Not sure if it's different from factory t56 and a4 or not but I'll let you know what color wire it was.
Old Apr 8, 2014 | 10:42 PM
N2Ojunky's Avatar
Thanks what shifter do you have?
Old Apr 9, 2014 | 05:32 PM
JustAFooL's Avatar
I run the quarter stick..
