80e tail housing o-ring?
Old Mar 28, 2014 | 11:45 PM
runsfromdacops's Avatar
Default 80e tail housing o-ring?
hey guys im working on a 08 2wd 80e out of a van.
when i slide the yoke all the way to the dust boot (1/4" before it hits) i can feel the yoke engage a oring inside the tail housing. the oring is not on the shaft but part of the tail housing.
the yoke is about 3.5"s on the machined part, do i need a longer yoke?
how far out do i need to hold the yoke for a irs car?
-alex
Old Mar 29, 2014 | 02:09 PM
No one knows?
Old Mar 30, 2014 | 06:49 AM
forcd ind's Avatar
some of the output shafts had less splines, used an o ring-diff type yokes, some had the first like 1/2" bored inside to fit over the oring
I slide the yoke all the way on, then pull it out aprx 3/4", meas. center to center to the rear ujoint with the rear loaded-you can load/unload the rear, see the diff in length rear to trans
Old Mar 30, 2014 | 11:54 AM
thanks for the reply.
th o ring on my trany is not on the output shaft.it seems like it is a part of the tailhousing, as it slides over the out side of the yoke.
i need to now if in need to get a longer output yoke to engage that o ring or will i be ok leaving it alittle short of that o ring
-alex
Old Mar 31, 2014 | 03:16 PM
I know someone has some insight here
Old Mar 31, 2014 | 03:25 PM
Ferocity02's Avatar
There is no o-ring on the inside of the tail housing, not other than the seal at the very end. There is an o-ring on some output shafts and prevent oil from getting into the splines and coming out the center of the yoke for bolt-on yokes. But it's not necessary to engage this o-ring when using a slip yoke.
Old Mar 31, 2014 | 10:25 PM
big thanks to jakes performance.
so only some 80s have this o ring as part of the tailhousing. and it basicly does the same thing as above. keeps oil out of the splines and no you dont need to engage it
-alex
