Wiring up NSS on 4L60e
Old May 2, 2014 | 12:42 PM
danieloneil01's Avatar
Default Wiring up NSS on 4L60e
I'm converting my 2003 Z06 to auto. I'm using a stand alone controller (PCS) and only need to hook up the reverse lights and park/neutral switch. Here's what I found and would like confirmation if it's right. I don't know if hooking it up wrong would cause damage to the NSS or not.
For the neutral safety switch the purple and yellow wires from my clutch switch go to C and D based on the connector on the left? But this might be the wrong diagram as I looked on my NSS and it's only 7 wires with 2 of them bigger bigger prongs than the other 5 (last picture).
Here's the clutch pedal safety switch that I will extend the wires to the NSS
I'm assuming this plug will be where I hook up the reverse light wires? If so which connections and what do does A, B, C and P stand for? Obvious would be P stands for Park?
Reverse light wires
Clutch switch wires
NSS
