4l80e build: what do I need to make it live?
Old Apr 27, 2014 | 09:11 AM
JDMC5's Avatar
Default 4l80e build: what do I need to make it live?
I'm doing a 4L80 swap in my 99 trans am. I have a 400-430 rwhp HCI ls1, I'm also running a circle d 3000 stall. If I had to guess what it will run it should be about 1.7 60ft 11.7 @ 117. Do I need the 300m input shaft or can I get away with stock? I plan on driving the car daily with track time maybe 1 time a year so I will be running street tires most of the time. Can you guys give a little insight on what's needed what's not and what's a good idea etc thanks
Old Apr 27, 2014 | 05:39 PM
Jake's Performance's Avatar
Stock input would probably live. The question is, how much is the tow bill home if it breaks?
How much is the time worth to R&R the trans?
How much is the fluid gonna cost?
Old Apr 28, 2014 | 07:05 PM
JDMC5's Avatar
Ok, I'm gonna go with the upgraded input shaft then.
Old Apr 29, 2014 | 06:56 AM
Mystery Bird's Avatar
Mine is stock. I'm cutting high 1.4s in the 60.
Old Apr 30, 2014 | 10:33 AM
Briou's Avatar
I am building a 700fwhp ls3 right now that will have a 4l80e behind it in a full weight 1970 Chevelle...the only upgrades I plan on doing is a rebuild kit with high friction clutch packs and the Transgo HD2 shift kit...I have a buddy with a 850hp turbo 5.3 in a fairmont that cuts 1.3s 60' and the only thing he has done to his 4l80e is the transgo HD2 kit, but only the parts that you do without tearing the case down....
Old Apr 30, 2014 | 11:56 AM
I've had stock input shafts live at 1200 RWHP in turbo combos. I've also seen them break behind stock 6.0Ls in 2500HD trucks.
The metallurgy on the stock shafts is very inconsistent and that is why we recommend a billet shaft at 750+ HP applications.
We warranty what we build and prefer to avoid failures. If you are building the trans yourself, you can definitely take that risk.
Old Apr 30, 2014 | 09:30 PM
lsxstudebaker's Avatar
this thing is gona be mean!
Old May 1, 2014 | 10:38 AM
Briou's Avatar
Jake, do y'all sell the billet shaft on it's own??
Old May 1, 2014 | 12:24 PM
Yes,
They are $350.
Old May 1, 2014 | 01:04 PM
got-a-ls1's Avatar
jake while were on the topic of input shafts... im running your stage 2 rebuild kit with a tci 300m input shaft and forward hub (you were out of stock of shafts at the time so figured id try the tci, good so far). what do you feel is a safe rpm differential to lock the converter (triple disk) im getting quite a bit of slip and want to lock third gear but i guess i dont know what type of rpm differential is safe to lock at. when i shift into 3rd gear the input speed of the trans is 4000 rpm while the engine rpm is 5700 rpm.
Old May 2, 2014 | 12:22 PM
vwdave's Avatar
Originally Posted by Jake's Performance
Yes,
They are $350.
Im used to the Dodge 47's costing $750.
Old May 2, 2014 | 07:12 PM
Yeah the Dodge piece also has the hub. A 4" billet costs more than a 1.25" and requires more time on a machine to cut off the excess.
Old May 2, 2014 | 09:19 PM
vwdave's Avatar
Makes sense.
