4l80 in a 99 fbody?
http://northtexasconverter.com/?page_id=8242
lol i spent over $3k to do the swap but that included $2000 for trans core and rebuild. Then the converter was $850 and needed a new crossmember, slip yoke, u-joint, and i went with a PCM4Less harness. The worst part of the whole thing for me was cutting the tunnel brace that is in the way of the plug. It's tough steel but with a air compressor and grinder it still wasn't bad. Trending Topics
Craigslist 4L80 $150
Transgo HD2 kit $120
Fti converter $750
BMR Crossmember $225
Connectors off ebay $50
Fluid/pan gasket and filter $80
Sonnax short shifter shaft $30
The stock driveshaft works if you get the correct yoke, stock flexplate works if you get the right converter. I made my own wiring just bought the connectors off ebay. I used the stock 4l80 dipstick that came with mine, just had to persuade it with a few bends. I had to cut a hole for the connector.....noooo way an air hammer or any hammer for that matter was going to clearance that enough. The stock 4L60 linkage works but you will have to modify the bracket to get the cable adjusted properly. I also spent about $250 on a good derale cooler with a fan and $80 on stainless braided lines but that's not "needed".
BMR 4L80E conversion crossmember (TCC020)
BMR 4L80E torque arm relocation crossmember (TCC021)
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
I got the one with the torque arm mount(pic #2).P.S. Kyle did i ever tell you that driveshaft safety loop i bought from your buddy saved my *** already
lol i had a junk u-joint and it broke, locked my slip yoke and shaft together and snapped the shaft off right at the loop. The only thing it didn't save was some light damage to my Y pipe and tunnel from the slip and 6" chunk of driveshaft that was flopping around... Other than that the loop did exactly what it was meant to and i couldn't be happier
lol i had a junk u-joint and it broke, locked my slip yoke and shaft together and snapped the shaft off right at the loop. The only thing it didn't save was some light damage to my Y pipe and tunnel from the slip and 6" chunk of driveshaft that was flopping around... Other than that the loop did exactly what it was meant to and i couldn't be happierWell it was a good thing you got that driveshaft loop from when you did.
If you don't have one and you break a driveshaft it can destroy the underneath of the car which is a real nightmare. A lot of guys don't realize they need a driveshaft loop before it is too late.
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
