4l80e swap vibration....
Old Oct 6, 2015 | 07:28 PM
JDMC5's Avatar
I have the exact same problem.
Old Oct 8, 2015 | 02:44 AM
Vetal's Avatar
Still haven't solved it... Can't make degree between gearbox and rear end less than 2* - both gearbox rear and torque arm front raised to the max
Old Oct 3, 2016 | 06:06 PM
Vetal's Avatar
A have some updates here, but still not solved the problem.
I have my driveshaft shortened and bushings in the transmission replaced - still vibration remains.
Today I've measured DS runout near the rear end - about .016", and I also checked how much can I moved DS by hand near the tranny tail, and it moves about .03" vertically. Does this seem normal?
Old Jul 4, 2018 | 11:27 AM
Cole Train's Avatar
how are your motor mounts? bad mounts can cause the driveline angles to be out of whack when under load. Mine are shot, like flopping in the clamshells shot...
