4l80e swap vibration....
For now I'm suspecting my driveline angles are wrong, engine is tilted down 4* in rear and rear end pinion is also tilted DOWN 1.5* in the front so there is 5.5* angle between their centerlines, while from what I read it must be 0.
since its longer, and now maybe pointing down more, the driveshaft actually comes out and goes up a little-I have had to split the floor open and mod it to get the proper angle
Only 2 things changed: tranny angle (possibly), and new steel driveshaft (which by the way appears to be too long according to Inland Empire troubleshooting guide)
Gurus, should I maybe remove tailhousing to check what's inside? Or is this normal play?
I don't know how was it when tranny was new. I suspect that due to vibration I might have done damage to the tailhousing...
Vibration will cause the bushing to wear. You also need to find the root cause of the vibration.
Your pan leak mentioned elsewhere was probably the harness connector and not the pan.
Vibration is caused (I believe) by 5 degrees between engine centerline and rear end pinion centerline, from what I read they should be parallel.
So, should I remove tailhousing and check the bearing?
I removed the tailhousing and to be honest bearing doesn't look beaten... Driveshaft moves considerably inside the bearing but the bearing itself doesn't look too bad...
Should I still replace this bearing, can it be replaced separately, not getting the whole tailhousing? What's the acceptable clearance for this bearing?
Anyways, I did match the pinion with the tailshaft which made them both -4 and it about eliminated all vibration. I have a little but nothing like I had.
there is hardly any distance of the shaft coming out of the rear housing
was the rear hanging lose or supported in the video
I've reduced angle between gearbox and rear end from 4.5* to about 2-2.5 degrees as well as rotated driveshaft 180* in the rear end yoke, vibrations reduced a lot but still far from comfortable cruising
