Tranny options
It's a 2000 z28 with a stock long block & 10-bolt, Strano bars, SFC, Magnaflow, Koni shocks. The car's got 150K on it and looking to upgrade over the next few years: 12-bolt or 9in rear, forged internals, forced induction. No more drag racing or nitrous, just some high-spirited commuting. Would like having my options open, meaning I need a tranny that can handle any plans I come up with, up to 500-600hp, which I understand is right in the T56's neighborhood. I'm going to call FLT later & get their advice as well...
(off to work in my wife's minvan ugh...)
Thanks!
-Mark
One weekend? No way unless you have done it several times already and have absolutely every part. I read that the cost with trans often comes in around $4000.
For $4000 you can get a very good trans from FLT. The replacement can be done in a weekend.
For $4000 you can also swap to a 4L80E, this will include a junk yard trans, a rebuild, conversion harness, crossmember and converter. Lots of detailed threads here on the subject. I doubt it can be done in a weekend.
If your car is undriveable I don't understand why you have to complete it in one weekend. With backlogs, shipping time, etc. it takes weeks to get any trans.
I'll need to get a good tranny cooler. Jeremy says a standalone unit, bypassing the radiator, is best; apparently, ideal tranny temp is down in the 150-160degF range, so running it through the radiator is actually pre-heating it. Who sells a decent one? I used to have a B&M but the hoses leaked and the fluid never got over 200 anyway, even at the track, so I got rid of it. The Best V8 Stories One Small Block at Time
