deep sump or stock pan? best fluid to use
Old May 30, 2014 | 07:22 AM
rorric's Avatar
Default deep sump or stock pan? best fluid to use
Just wondering if any buddy runs a deep pan on a 4l80e in a f body or is it best to use stock pan? Also wondering what's the best fluid to use . This is a new rebuild
Old May 30, 2014 | 04:51 PM
NorthTexasConverter's Avatar
You'd most likely be best off with a stock pan.
Fluid isn't a big deal, store brand Dex would suffice.
Old May 30, 2014 | 09:35 PM
Cam72aro's Avatar
The problem with the deep sump pans is they decrease your ground clearance significantly. I was able to find a shallow cast aluminum pan from a company called PML performance. Not sure if they are still in business though. Otherwise I would run a stock pan.
Old May 31, 2014 | 02:33 PM
Snap-On's Avatar
The stock pan is fine... just use dex fluid, nothing special. Invest your money on good external trans coolers.
