4l60e possible vibration issue
Old Jun 17, 2014 | 07:30 AM
11z71's Avatar
Default 4l60e possible vibration issue
So since I've installed my Strange S60 and new drive shaft from them over the winter I've been chasing a really bad vibration at speeds above 50-55 mph. The faster you go the worse it gets and you can actually here it. It's worse when you decelerate and almost subsides when back on the throttle but not 100% gone. I"ve played with pinion angle to no end but nothing has changed it. This morning I pulled the driveshaft out of the car to send it back to Strange just verify that the balance is correct. While it's out im going to replace the taillshaft bushing and seals. So here is my question, when the driveshaft yoke is installed into the rear of the transmission there is a tiny bit of play up and down and side to side. If you put enough pressure on the yoke you can almost push the yoke shaft away from the taillshaft seal, but just barely. With the driveshaft out of the transmission, the transmission tailshaft has a **** ton of up/down and side to side play. I can almostpush the shaft by hand inti the seal.Is this a normal amount of play with the shaft out? I'm just wondering if this normal because the once the yoke is in the housing the bushing keeps it from moving around? Thanks for any insight and replies!
Old Jun 17, 2014 | 09:16 AM
high n dry's Avatar
If u have a strange yoke, that might b the issue(not machined correctly?)... from what i been told strange yokes are no good. Thats why i went with spicer brand instead when i S60'd my car.
Old Jun 17, 2014 | 09:35 AM
11z71's Avatar
Yeah I did some searching on that and seemed like the only cars that had issues with their yokes were M6 cars. Not sure if A4's and M6's use the same yoke?
Old Jun 17, 2014 | 11:29 AM
mrvedit's Avatar
Moderator
CORRECTION/UPDATE - See below
I mostly only have experience with the nearly-new 4L60E that I build (and rebuild over and over again to experiment with parts), but these have very little side-to-side play at the end of the tailshaft.
As much side-to-side play as you described IMHO indicates excessive wear in the bushings.
We had a similar question a year ago and IIRC, Frank at Performabuilt said that 1/4" play was OK, but it should not be too much more than that. Certainly not the 1" you describe.
Perhaps one of the pro builders can confirm whether this is causing your vibration.
Old Jun 17, 2014 | 05:07 PM
performabuilt's Avatar
LS1Tech Sponsor
I would certainly check at least the tail housing bushing as its pretty easy .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 17, 2014 | 05:50 PM
mrvedit's Avatar
Moderator
Correction/Update
I had a chance to check one of my spare, like-new, 4L60E and I noticed it has moderate side-to-side play in the tail shaft. With some force, I could push the tailshaft to the tailshaft seal. I estimate you can only move it 1/4" before it touches the seal.
IIRC from a thread a year ago, the OP removed the tailshaft housing and had well over an inch of side-to-side play, maybe even 2 inches. That is clearly too much.
Old Jun 17, 2014 | 06:15 PM
11z71's Avatar
I do have a seal and bushing to install while the shaft is out getting checked at strange.
Old Jun 17, 2014 | 06:17 PM
11z71's Avatar
Originally Posted by mrvedit
Correction/Update I had a chance to check one of my spare, like-new, 4L60E and I noticed it has moderate side-to-side play in the tail shaft. With some force, I could push the tailshaft to the tailshaft seal. I estimate you can only move it 1/4" before it touches the seal. IIRC from a thread a year ago, the OP removed the tailshaft housing and had well over an inch of side-to-side play, maybe even 2 inches. That is clearly too much.
Ok that makes me feel better then. I definately don't have 2 inch's of play. So I guess the tailshaft bushing is really the only means of support in combination with the yoke being installed in the housing.
Old Jun 17, 2014 | 06:35 PM
LS1Tech Sponsor
Yes the case output shaft bushing provides very little support other than a guide for the rear planet assembly. I can however tell you this if its totally missing it will cause a decent vibration. Ask how I know this well years ago I had a guy come in he had had his new trans am to the dealer multiple times and a few trans shops who had replaced drive shaft. joint's, tail housing and Bushing mounts and more he had a whole list of things. I removed the tail housing and looked with a flash light and low and behold no case bushing at all. Never been one installed. We removed the reluctor gear and with a bit of improve of a steel pipe installed a bushing, Put all back together and wahla no vibration.
__________________
Call 888-744-6542
Old Jun 17, 2014 | 07:41 PM
11z71's Avatar
Wow, can't believe the dealer didn't catch that!
Old Jun 18, 2014 | 09:58 AM
97camaro383's Avatar
I have the same setup (ss3600 and S60) and I've always had a little vibration. I'm curious to know what they say about the driveshaft
Old Jun 18, 2014 | 10:25 AM
11z71's Avatar
I'll definately update this once it I here from them.
