A/C Delco part numbers
Old Jul 30, 2014 | 06:16 AM
BigVin's Avatar
Default A/C Delco part numbers
Where do you find part numbers for trans parts? Is there a parts book for sale or is there some other way to find numbers? Thanks
Old Jul 30, 2014 | 06:33 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
http://performanceworks1.com/PDF%20F...s%20Manual.pdf
Old Jul 30, 2014 | 08:54 AM
mrvedit's Avatar
Moderator
Tell us what parts you need and we will give you part numbers and recommendations.
Old Jul 31, 2014 | 03:35 AM
BigVin's Avatar
One part is a 96 4l60e reverse drum.
Old Jul 31, 2014 | 08:17 AM
mrvedit's Avatar
Moderator
As far as I know all 4L60E from all years (and even 700R4 3/87 and later) use the same reverse drum. There are two types available - the cheap generic ones for about $60 and AC Delco ones for about $95. (Both are probably Chinese made but I would trust AC Delco for better quality control.)
A distributors catalog shows a part number of 8681295. I'm not sure if that is correct, but a search on ebay shows A/C Delco reverse drums.
Other online vendors have them too; PM me if you need a source. (Links to non-sponsors are frowned upon.)
Old Aug 1, 2014 | 05:28 AM
BigVin's Avatar
Thank you. What I really want is the distributors catalog that you got that part number.
Old Aug 1, 2014 | 05:58 AM
6t7gto's Avatar
Maybe here....
http://www.transtar1.com/catalogs?c=1087
Old Aug 1, 2014 | 09:13 AM
mrvedit's Avatar
Moderator
Originally Posted by 6t7gto
Exactly what I have, but as far as I know they only sell to trans shops and not retail. (A local shop just orders whatever I want from them.)
However, I find that when it comes to common hard parts, Transtar often only supplies cheaper non-OEM parts. In other words if you order the reverse drum from Transtar you will get the $60 Chinese part and not the A/C Delco part. The cheaper part is good enough for your average rebuild.
Old Aug 1, 2014 | 11:19 AM
that 8681295 shows up on Page 605 of the PDF link of post #2 I posted in this thread.
Old Aug 2, 2014 | 04:26 AM
BigVin's Avatar
thank you
