Is '06 4L60E pump and '04 pump interchangeable?
http://www.sonnax.com/parts/2168#tabs1-instructions
Note the "Early pump cover" and "Late pump cover" pictures. If both pumps are identical in this area they should be interchangeable, but many (most?) '06 pumps will be "late pump cover" model.
Also what do you mean by "one spring" and "two springs"? Are you referring to the pump slide spring? Very early (e.g. '94) pumps had two springs but as far as I know, GM changed to just one stiffer spring around '98. The Transgo and Sonnax shift kits include an even stiffer spring for higher rpm operation.
So if I don't have a 06 pump to compare with, how can I know what year a particular pump is?I?
Especially look at where the boost valve inserts into the pump.
Late-model pumps have a square cutout area for boost valve while older (pre-06) do not.
Also '06+ ISS pumps have a hole and mounting area for the ISS sensor.
Here is a picture of a new-style pump with ISS - note the square cutout on the bottom left for the boost valve. Also the wiring for the ISS. (The clip for the ISS wiring is in front of the boost valve, making it difficult to change the boost valve with the trans in the car.)
http://thumbs4.ebaystatic.com/d/l800...22449080_1.jpg
Also older pumps seal with an o-ring slotted into the pump housing while newer pumps are smooth and the seal is built into the case.
However the biggest issue is the ISS. Regardless of the Boost-valve style and sealing style, an ISS and non ISS pump are not interchangeable; the position of the teflon seals on the input shaft are even different.
