4l80e Rebuild kit
It has clutches, steels, OH gaskets and seals, all 3 of the sprags (over $100 alone), internal wiring harness, pressure switch, solenoids ( again over $100 in parts), complete bushing kit. Complete thrust washer kit, rollerized forward hub, rear torrington kit to rollerize the output, boost valve and pressure regulator spring, as well as other parts. The tech info included will save you hundreds in rework.
We don't use Alto red material in anything.
. I will be emailing you shortly The Best V8 Stories One Small Block at Time
