V6 4l60 to 5.3 help please
Old Aug 6, 2014 | 04:44 PM
nofun's Avatar
Default V6 4l60 to 5.3 help please
So I bought a V6 4l60 a year ago to back a 5.3 ( both 2001 ). Can I run the
V6 torque converter with the flex plate it's has both holes. Will I need to
shim it ???? I bought the trans for mock up and j-yard said it would work.
Now I'm ready to rebuilt it, but need to know if I can get the torque converter bolted up.
thanks bob
Old Aug 8, 2014 | 10:11 PM
zgp's Avatar
zgp
thanks bob
What is the gap between the converter and flex plate? You must have at least a 1/8 gap between when it is bolted to the engine. The max you want is 3/16".
Old Aug 9, 2014 | 09:37 AM
mrvedit's Avatar
Moderator
You will need a flexplate spacer so that the converter pilot is properly seated at the end of the crank. This thread covers some details:
https://ls1tech.com/forums/automatic...ifference.html
I list the necessary part numbers in post #11.
While not trivial, I would recommend removing/replacing the valve body separator plate and drilling it at least according to the Transgo separator plate "stock" specs for a V8. If you do that, the "Vette Servo" would be a good ($15) addition.
Old Aug 9, 2014 | 11:00 AM
nofun's Avatar
Thanks great info.
