4L60E Input Shaft Leaking
Old Sep 21, 2014 | 07:43 PM
bbond105's Avatar
Default 4L60E Input Shaft Leaking
How do you seal an input shaft that is leaking between the shaft and input drum?
Old Sep 21, 2014 | 08:36 PM
mrvedit's Avatar
Moderator
Bubble gum.
Seriously, you have to replace it. Assuming you buy a new GM one, the shaft and drum come as one unit.
I recommend adding the Sonnax input drum reinforcement kit which strengthens this area with a steel ring. The kit includes a custom overrun piston which only works with the older style aluminum forward piston.
(I need to check the details, but Sonnax now also has a billet overrun piston which works with the new style steel piston.)
Old Sep 21, 2014 | 08:55 PM
bbond105's Avatar
My son is a machinist so we modified the stock input drum to except and bolt on end plate similar to the Sonnax Smart-Tech Input Drum. Installed a new input shaft along with the Sonnax input drum reinforcement kit. Anyway now it’s leaking. I removed the shaft today, cleaned it up and reinstalled it with green Loctite and left it alone for the Loctite to set up. I am hoping this will seal it up.
Are these things so acceptable to leaks when you change out the shaft?
Old Sep 21, 2014 | 10:21 PM
mrvedit's Avatar
Moderator
My only experience is pressing a billet input shaft into the Smart-Tech input drum; those instructions say to use red Loctite.
Old Sep 27, 2014 | 09:10 PM
bbond105's Avatar
The green Loctite seemed to work. It passed the leak test so I installed it.
Old Sep 28, 2014 | 10:57 AM
built408's Avatar
You will see some small bubbles on almost all of them.
I put them in a heated parts washer, you will find a lot of input shafts loose in the drum that way.
I press out and put green sleeve retainer on all shafts. Then press back in.
Old Sep 28, 2014 | 05:08 PM
bbond105's Avatar
Thanks for the info built408.
It didn't seem right that I would have to buy a new drum and shaft just becouse of a few bubbles. The green sleeve retainer I used stopped the bubbles so I installed it. I guess time will tell if it is truely repaired.
