C5 filling question
Old Sep 27, 2014 | 11:23 PM
BOTTLE ROCKET's Avatar
Default C5 filling question
Sorry for a newbie type question, but how do you get the trans fluid into a new C5 A4? It holds 10-12 quarts. I turned it on its side so I could get some addional fluid in, but it still only held around 4 qts before it started coming out...
I don't want to run it long with low fluid, but it has to be running or the fluid will flow out of the pan.
Thoughts?
Thanks
Old Sep 30, 2014 | 10:52 AM
bbond105's Avatar
I haven’t had the opportunity to work on a C5, but I am sure it is like most other GM transmissions where you fill and check the fluid with the engine running and gear sector in park. Hope this helps.
Old Sep 30, 2014 | 12:39 PM
mrvedit's Avatar
Moderator
No, the trans is stuffed into the rear and IIRC doesn't have a dipstick tube making it very hard to check and fill. I ask one of my C5 friends to answer this.
Old Sep 30, 2014 | 12:56 PM
RonSSNova's Avatar
Hey, I believe I answered this on the C5 forum, correct?
Car needs to be up in the air so you can get under it. With it running, and a pump or fluid transfer system of your choice, add fluid until it just begins to run out of the fill hole. Put the plug back in, get in the car and cycle the shifter through the gears. Keep your foot on the brakes. Maybe let the tires rotate while in drive, but stop them before going back to reverse.
Get the trans temp up to 100 deg or so, then top it off while idling in park.
Enjoy the ATF bath......
Ron
Old Oct 1, 2014 | 09:31 AM
Ron
Yes Ron; You usually do wind up answering a LOT of my "odd" questions. (Thanks)
Over the years I've installed a dozen trans and NEVER had to ask the proper way to fill one.
Even Shane told me, "just pour/pump it into the fill hole. Between it and the TC, it should hold most of it" Well Im not sure how big their pan is, but mine will only hold about a quart before it starts running out. That's a lot of pumping to get 10-12, and THAT EXAUST IS HOT!!
