Is there any shifters that allow 1st to 3rd?
Old Oct 14, 2014 | 09:56 AM
mike13's Avatar
Default Is there any shifters that allow 1st to 3rd?
Looking for a shifter for my 4L80E that allows you to go 1st to 3rd, without having to ratchet past 2nd gear. Any suggestions?
Old Oct 14, 2014 | 07:57 PM
JustAFooL's Avatar
With the pro stick, if you hit it just right, you can pull the lever and hold it in allowing it to slip past second and hit third. I don't know that the Trans will allow it to do that though.
Old Oct 17, 2014 | 02:48 PM
Camaro396's Avatar
Why on earth would you want to do that?
Old Oct 17, 2014 | 03:16 PM
mike13's Avatar
Because I have a Jake's Performance 4L80e, I launch off the transbrake in 1st, move the shifter to 3rd and the transmission shifts auto. I modified the detents on the stock shifter and It works but would like to go to a aftermarket shifter.
Old Oct 19, 2014 | 01:48 PM
JustAFooL's Avatar
Since the transmission isn't a MVB, why couldn't you just leave the shifter in D and csome off th brake like that instead of having to shift? If that's what your wanting to do though, look into a pro stick.
Old Oct 19, 2014 | 02:57 PM
mike13's Avatar
It has to be in 1st for the brake to work, Jake did develop a brake that works in drive but I have a earlier version that requires the car to be put in 1st manually for it to work.
Old Oct 19, 2014 | 03:51 PM
JustAFooL's Avatar
Got ya. That shifter will do what you looking for though. The quarter stick will as well but they no longer offer it in a 4 speed.
Old Oct 20, 2014 | 06:39 AM
Jime's Avatar
Whats wrong with just shifting to 2nd after launch then immediately to 3rd? I'm using a Winters Sidewinder and it works fine that way.
Old Oct 20, 2014 | 07:40 AM
mike13's Avatar
nothing I guess, was just looking for a shifter that is capable of going 1-3.
Old Oct 20, 2014 | 09:12 PM
62c10's Avatar
http://www.wideopendesign.com/Produc...s-Shifter.aspx
Remove the gates you don't want.
