rpm+gear = wrong speed?
Old Oct 23, 2014 | 10:52 PM
ben husen's Avatar
Default rpm+gear = wrong speed?
kinda the right sport but this is for my truck 82 chev with a built 383 doing a gear ratio calculator and in 2nd gear at 6k i should be doing 111mph
38in tires 4:10 gears 1st 2.48 2nd 1.48 3rd 1.00 3k stall
i know i was in 2nd gear tonight and gps said i was doing 65ish but thats what 1st should be doing at 6k not 2nd this is the calculator im using
http://www.planet4x4.net/forums/calculator.php
thanks for any help
Old Oct 27, 2014 | 12:31 PM
ben husen's Avatar
Anyone?
Old Oct 27, 2014 | 12:47 PM
62c10's Avatar
Did you actually measure your tires? Most off road tires aren't actually the size they say they are. That may be some of it.
Old Oct 27, 2014 | 06:09 PM
ben husen's Avatar
yea there 38.5 boggers but measure at 38but even an inch difference wouldnt make 65 vs 110
Old Oct 27, 2014 | 07:27 PM
mrvedit's Avatar
Moderator
I tried another calculator and got the same results as you.
So, one of your assumptions has to be wrong:
1. 4L80E with 2.48 and 1.48 gear ratios
2. 4.11 rear end
3. You know what gear you are in
4. Your tachometer is accurate
5. Your truck doesn't have a "Low range" underdrive unit
You would not be the first person here who thought they had one rear ratio but turned out to have a completely different ratio. You can easily test this with the wheels off the ground and the trans in neutral. Mark a tire and count how many driveshaft turns it takes to turn the tire one revolution.
Have you considered the tach accuracy?
Old Oct 27, 2014 | 11:00 PM
ben husen's Avatar
the rear end gears say 4:10 right on them iv had the pumpkin cover off and looked its a th400 not 4l80e but same gears i know i was in 2nd put it there manually and i dont have 3rd it slips out i dont have an under drive unit i put this truck together my self tcase wasnt in 4 lo i tested that the next day just to make absolute sure even tho i knew were 4 lo was its not the highest quality tach but i couldnt see it being off more then a couple hundred rpms i guess is there any other way to check rpm exept with a different tach
otherthing i was talking about with a buddy tonight since i have a 3k stall it just doesnt lock up and has that much slip?
Old Oct 28, 2014 | 09:49 AM
bbond105's Avatar
If 3rd gear is slipping what is the possablity that 2nd is slipping also?
Quote
Old Oct 28, 2014 | 10:25 AM
ben husen's Avatar
Doesn't feel like it 3rd just goes in and slips out fluid didnt smell burnt tell I tryed for 3rd gear trans is fresh rebuilt 3rd has like a line pressure issue
Old Oct 28, 2014 | 11:08 AM
62c10's Avatar
I know a small difference in tire size won't make a huge difference that's why I said it could be some of it. Some tires are way worse then 1" some "40's" are actually closer to 37" when measured.
Old Oct 28, 2014 | 06:06 PM
ben husen's Avatar
yea i know that lol had plenty of buddys wonder why there truck sat so small
like tonight went for a long drive to warm up my truck every time i tested it at 3400-3500 in 2nd i was doing 45 mph but after the drive and using reverse more i may be thinking that it may be sliping a lil cuz i noticed reverse slipping a lil bit
Old Oct 29, 2014 | 04:50 PM
jimmyg's Avatar
If they say 41 10 they are 373 I think ring gears don't read like that 41 10. 41 teeth on ring gear 10 teeth on pinion look online will tell u I think it's 3.73
Old Oct 29, 2014 | 07:00 PM
ben husen's Avatar
that would make it even more off lol i cant remember if it said that or if i had checked with them numbers or not been over a year since i had the cover off
Old Oct 30, 2014 | 05:31 AM
jimmyg's Avatar
Sorry it's 41 10 is 410 , 41 11 is 3.73
