4l60e
Old May 25, 2004 | 05:53 PM
SuperSam's Avatar
Default 4l60e
Can figure out what's wrong. After the car warms up... it doesn't shift into overdrive....The rest of the gears shift fine. The tranny was rebuilt last week, Also intalled were a PI 4400 stall, B&M tranny cooler, and a shift kit. Anyone have that problem?
Old May 28, 2004 | 10:18 AM
Smitty's Avatar
Have the transmission scanned as the the problem occurs.A faulty 3-2 downshift solenoid can cause a no overdrive concern,assuming all other work was done correctly.
Old May 28, 2004 | 11:16 AM
Rock-On's Avatar
Default hey
Hey It could be a temp sensor as well, get aa good scan on this unit, is it getting lock up?? hope this helps....Dave
Old Jun 1, 2004 | 02:04 PM
onequick5.3's Avatar
I had the same probelem with my truck. So i took it to the dealership and they said it was a valve that was stuck that wasn't allowing it to go into overdrive. They pulled out the valve body cleaned it and installed a valve and bearings and it was fixed.
