4l80 tcc issue
Old Nov 9, 2014 | 08:59 PM
1-87 chevy's Avatar
Default 4l80 tcc issue
ok guys heres my problem I have a boosted 2002 Silverado that I just did a 4l80 swap on . I changed harness and loaded a tune from a 02 2500 . the tranny locks ups the tcc in reverse every time ,any ideas what it might be .the tranny is 2004 model . thanks for looking
Old Nov 9, 2014 | 09:48 PM
Jake's Performance's Avatar
Internal problem. Try increasing the idle speed. You can also change the PR valve to a Sonnax line to lube and see if that helps.
Old Nov 12, 2014 | 03:24 PM
6point0 goat's Avatar
I was having the same issue, i picked up a take out trans to replace the other unit that was causing the issue and it seems that the issue was an internal leak of some sort. I thought it was an electronic gremlin since I was swapping a 4L80e into my GTO but it was the trans itself. Its probably a cross leak.
