th400 foward / direct steels, is .068'' to thin?
Old Dec 1, 2014 | 06:25 PM
monte383sbc's Avatar
Arrow th400 foward / direct steels, is .068'' to thin?
iam stacking up the forward and direct drums in my th400 and to my correct clearance I would have to use a few . 068''s with .077''s and a .092'' steels or do some machine work, my question is a .068 steel to thin and prone to worpage in the forward and direct drums? I was always told never to go less then .070'' on the steels. any help is appreciated thanks matt
Old Dec 1, 2014 | 11:28 PM
SnIpEz's Avatar
It will be fine
Old Dec 2, 2014 | 04:54 PM
PBA's Avatar
PBA
As long as you are using the Hi-Energy clutches, you will be fine. Warpage only occurs when the clutch burns, not the other way around.
