2wd Silverado trans into my 1999 camaro with lm7
Hey guys , found a local guy selling a 4l60e out of a 2003 c1500 silverado pickup. It has the bolt in the 12 oclock position on bell housing which is also a 2 piece. It looks like the shaft is the right size, he says its a 2wd trans , ive attatched pics. Any chance this will bolt up to my lm7 in my 1999 z28
Moderator
Yes, it is compatible and will bolt up exactly right.
Yup, the bolt hole in the 12 O'Clock position indicates it has a 300mm input shaft which lets it bolt up to any LS engine. Your '99 PCM will in turn be electrically compatible with any '96 through '07 4L60E/4L65E/4L70E.
