Making base to mount shifter M6 to TH400 swap
Old Jan 5, 2015 | 08:34 PM
Jason94z's Avatar
Default Making base to mount shifter M6 to TH400 swap
So I have this big hole in my tunnel I need to close up and mount a shifter to.
Is 1/8" aluminum plate strong enough? I was going to get a 8.5" x 8.5" square, trim some edges, and bolt to the tunnel using existing self tapping screws and holes, some RTV to seal it. Then mount the B&M ripper to that.
Sound good?
Or does someone make something I can just buy?
Old Jan 5, 2015 | 09:12 PM
JustAFooL's Avatar
Nobody makes anything like that. That's exactly what most people do though.. It will be enough to hold the shifter and not flex.
Old Jan 5, 2015 | 09:14 PM
bbond105's Avatar
I cut the tunnel out of an auto car and welded it in. You can go to a you pull it yard and cut the piece you need and use screws to bolt it down.
Old Jan 6, 2015 | 11:18 AM
Jason94z's Avatar
Thanks guys.
I'm terrible at fabricating anything. I'll give it my best
