JW Flexplate. What Bolts?
Anyone have this problem?
Chris
It's not even close Chris. The stocker has a crank flange built in that's probably 1/2 thick that the bolts go through. The j.w is a flat plate where it sits on the crank but has an overall dish to make up the depth.
I have never read of anyone finding the ARP 0.880 bolt length too long.
I just measured the depth of the threads on my aftermarket crank and the holes are .950 deep.
The LS2 is currently being replaced with a stroker 419 LS3. The 4150 style intake manifold (with EFI throttle body) works well for me and confuses people looking at it.
2 questions while I have you here. Does your steam vents seem to do okay running into the overflow tank like that? I may steal that idea if so. lol. Are the rears blocked?
also, How do you like the Corvette accessory system on there? I bought the pump and balancer for that system but still need to get that $540 kit to complete it. Did it install easy with no hang ups?
Here is a picture of my engine the way it sits....incomplete.
The steam venting into the overflow tank did not work well - the tank would overflow after a few track runs. I there drilled and tapped a hole into the thermostat cover which worked well but looked a bit odd.
Just today I took my aluminum radiator to a welding shop to install an aluminum AN-4 fitting. I just order an AN-4 steam pipe setup from ebay seller alper-motorsports. The rear ones are blocked.
The previous picture shows an F-Body accessory setup using the Kwikperf brackets. They worked poorly as they mount the PS pump in such a way that it always leaks. I have since then changed to the new Holley brackets which work and look better.
The following pictures show those changes (sorry pic quality isn't as good):
I also now have a 6-point roll bar:
the .880 ARP Flexplate bolts screw all the way in with no problem.
I'm getting mixed ideas of what to seal them with when installing so that's my next venture. Red Lock Tite or some Ultra RTV?
