Adaptor for BOP transmission ?
I have searched without luck for info on mating a Buick TH350 or TH400 to an LS3. Does anyone know if this is even possible? Who makes adapters or bell housings?
Moderator
The Chevy bolt pattern is basically the same from SBC/BBC to LSx.
I found this adapter plate:
http://www.speedwaymotors.com/Chevy-...late,3281.html
You would also need the correct flexplate and/or spacer. No idea of a BOP converter has the same bolt pattern as a Chevy.
My question is why? Why not sell what you have and buy a Chevy TH350 or TH400. I suspect the BOP version might fetch more due to relative scarcity.
