Need Help with 4L60 - TC not locking?
1. Codes, perhaps hidden, in the PCM - scan the PCM for codes
2. Worn valve body (I don't know if a '94 has the troublesome TCC valve.)
3. Worn out converter
Since the problem occurred after the rebuild, I would also suspect a missing o-ring on the input shaft.
A local non-chains trans shop should be able to diagnose that fairly easily by hooking up a scanner and testing the gears and lockup.
Regardless of whether you accept their remedy, please update this thread with what they said or any progress.
