Installing th400 and have a few questions
Old Apr 10, 2015 | 04:31 PM
25thhawk's Avatar
Default Installing th400 and have a few questions
Bolted trans up and everything fit fine, Im using a tci flexplate and a ptc converter for th400-ls1, so I thought everything would bolt up without shims, but the converter to flexplate spacing is .206. So my question is, do I shim the converter pads or the entire flywheel? How much engagement from the converter pilot do I need into the crankshaft? Thanks
Ryan
