Need advice on stall, 4L80E turbo.
I just had my 4L80 rebuilt with a hughes race kit and transgo shift kit, Now I need to figure out what my stall speed should be. Car is a 1987 mustang, motor has a 03' LS6 cam in it, and has siemens 80lb injectors, 76mm turbo. Car will be street/strip, anyone with a similar setup? The forced induction is whats making me second guess my stall speed, tranny builder suggested 2500 stall.... what do you guys think?
Hp: 550 Tq: 575
Car weight: 3,000
Gears: 3:73
Cam specs: 204/218 .551/547 Int CL:120,Exh CL:115 LSA:117.5 Cam Base Circle 19mm
Hp: 550 Tq: 575
Car weight: 3,000
Gears: 3:73
What engine is this? 4.8? 5.3? 5.7? etc. Unless you are working with over 400 inches of displacement 2500 stall isn't going to do a whole lot for you in terms of getting into boost. What's the AR on the turbo? .96?
