Is this normal for a 4L80e??
Old May 6, 2015 | 03:04 PM
Ron_Stoppable's Avatar
Default Is this normal for a 4L80e??
I had my trans rebuilt last month and plan on installing this friday. Everything looks good and turns over smooth ect but I was curious about the input and output shaft. Are they independent of each other? Because when I rotate either one, they do not affect each other. I could have swore that when I dealt with my first 4L80e that when I rotated the output shaft in gear that it would make the smaller "center" input shaft rotate. That isnt the case here, they both rotate smooth with a "normal Draginess" but they have no affect on each other in gear. Just inspecting it on the bench beforehand.
https://youtu.be/hIk8NODmCqs
Old May 7, 2015 | 08:54 AM
dw456post's Avatar
They are independent. That's how the trans is able to shift gears and have different output shaft speeds at the same input speed.
Old May 7, 2015 | 05:46 PM
Ok, thanks! I can stop stressing now haha good to know
