4L60E Torque Converter Swap Please Help!
1. Use an impact wrench, typically with an impact socket u-joint. Any 18V+ battery impact wrench that can remove wheel bolts should have no problem with this.
2. Have a friend hold the crank with a long breaker bar and a 24mm socket while you use a simple socket wrench or even a box-end wrench.
3. Use a flexplate holding tool, they are about $40 on ebay - search "ls1 flexplate holding tool". This is almost a necessity if you plan to accurately torque the bolts back on.
Sorry to hear you stripped your bolts. Hopefully someone has ideas on how to proceed.
Are you saying that you rounded off the outside of the bolt head?
I had to use my set to get stripped exhaust bolts out. My dad gave it to me since he never used them, so I didn't have to drive to the store.
