manual to automatic conversion Reverse and nuetral lights
Old May 22, 2015 | 01:07 PM
Bobs-00-SS's Avatar
Default manual to automatic conversion Reverse and nuetral lights
I am in the middle of my swap. is one of the connectors inside the console for the back up lights? and for the nuetral safety wires to i just splice into the wires at the clutch pedal switch? Thank you
Old May 22, 2015 | 07:52 PM
bbond105's Avatar
What kind of car and shifter do you have?
I have attached some wiring diagrams and notes for a 2002 F-Body. Some of the notes I got from different post and may not be accurate. I never took the time to correct them, but between the notes and wiring diagrams you should be able to figure it out.
Attached Thumbnails manual to automatic conversion Reverse and nuetral lights-orn-blk-wire-park-neutral-position-swicth.gif   manual to automatic conversion Reverse and nuetral lights-tcc-brake-switch.gif
File Type: doc
File Type: doc
File Type: doc
Old May 22, 2015 | 07:55 PM
bbond105's Avatar
Here are a few more.
Attached Thumbnails manual to automatic conversion Reverse and nuetral lights-chevrolet-camaro-shift-interlock-circuit-wiring-diagram_.png
File Type: doc
Old May 23, 2015 | 02:32 PM
Mappinsj's Avatar
i did this swap, decided reverse lights were for electricians.
Old May 30, 2015 | 07:38 AM
AINT SKEERED's Avatar
I spliced into the reverse lights on wiring harness where it plugged in on passenger side of the transmission. Its a brown connector.
As for clutch switch, get some male butt connectors and slide in the switch after you unplug it .use the lower clutxh switch by the floor board
Old Jun 1, 2015 | 09:21 AM
jlaudioholic's Avatar
Default Swap wiring
Dont forget to wire up the reverse lockout. I put that on the I'll do it later list whsen I did my swap. Well I didnt get around to it and managed to accidently bump the shifter into reverse while doing 40mph and guess what? Broke 4l60
