FTI LS brawler converters
A 3200 stall isn't to radical and with a stock engine the true stall will probably be lower. The stall will vary from one engine to the next according to the torque it makes. For example that converter with a stock engine may stall at 2900-3000 because it's not that powerful. If you bolt that same converter to a supercharged engine that makes lots of power down low it may stall at 3400-3500.
The reason people need a higher stall is because many engines actually make less torque down low with an after market camshaft (and idle ruff) but more power as rpms rise. A higher stall is used so the engine rpms will rise high enough so that the engine is starting to make good power at the same time as the converter starts working to make the car move.
Instead of starting at 2800-3200 where high torque application causes a sort of engagement to the drivetrain and having to climb/accelerate thru all that low horsepower part of the curve, a 'higher' stall will start more into the 'meatier' part of the curve. You're not wasting time(1/4 mile ET) climbing thru it. And that applies to every gear.
