4l60e las
Old Jun 10, 2015 | 10:56 PM
mechamta98's Avatar
Default 4l60e las
I bought this trans and wanted to know if anyone has any info on what might be done to it or who built it. The guy i bought it from said he bought it in a car he was parting and it was "built" but has stock shift servo.
Old Jun 11, 2015 | 11:37 AM
GMCSIERRA5.3's Avatar
never heard of it..but if it has a stock servo im almost positive it will not be a built unit
Old Jun 12, 2015 | 01:02 PM
mechamta98's Avatar
that's what I was thinking but I got a half way good deal on it. The guy was running a 250 shot and lifting tires off the ground. I did not think a stock 4l60e could do that.
Old Jun 12, 2015 | 01:51 PM
mrvedit's Avatar
Moderator
If you are referring to the servo cover, a fancy one only indicates that it has a billet 4th gear servo. If you aren't racing in 4th gear, or pulling a trailer in a truck, you don't really need a billet 4th gear servo. More for looks than need; many good builders will skip it.
Be sure you are getting the correct type of trans - the LT-style and LS-style are incompatible.
Old Jun 12, 2015 | 02:08 PM
bbond105's Avatar
Most likely whoever built the trams was proud of it and chiseled their initials into it.
Old Jun 12, 2015 | 08:39 PM
mechamta98's Avatar
Yes i was referring to the servo cover. i just went from 273 gears to 342. so there was no chance in hitting 4th gear before.
Old Jun 12, 2015 | 08:47 PM
mechamta98's Avatar
my original plan was going to find someone to put some new clutches in for me and tell me what was done because fluid was a little dark when i bought it. but stock 165000 mile trans did not make it through the dyno with new build, so had to get trans in so it can get tuned.
