4l60 or 4l80
Old Jul 8, 2015 | 11:11 PM
jcob's Avatar
Default 4l60 or 4l80
Trying to decide on a transmission for my car. Either keep the 4l60 and rebuild it or go to a 4l80. Currently my 4l60 has a broken sprag but if I pull it out I plan on rebuilding it and upgrading it, bc its been a year and a half since I rebuilt it. I want a transmission that will hold up to 800hp. I have a 3400lb nitrous car. I like how it does with the 60 but I want something that isn't going to break. I'm looking around $800-$1000 more to upgrade to a 4l80 including the cross member, harness and drive shaft.
Old Jul 9, 2015 | 07:54 AM
SCott5's Avatar
4L80. Stock rebuild kit with a good stall and it will easily do what your looking for
Old Jul 9, 2015 | 08:13 AM
mikesimpalass's Avatar
x2 on the 4l80e. I think at your power level, no matter how well they are built, a 4l60 is going to have a short life.
I don't make nearly the power you do, but I still went with a flt 4l80 in my car and I don't regret it. it is one tough transmission
Old Jul 9, 2015 | 09:37 AM
Dark SS's Avatar
I don't think a stock 4L80 with a shift kit will take 800HP and nitrous for too long.
Old Jul 9, 2015 | 10:02 AM
it doesn't take much for an 80e to hold a lot of power. if you get one rebuilt. have the trans builder dual feed the direct clutches, thats the week link on a stock 80e, once you do that, you will have one tough transmission. I don't know if it would hold 800hp at that point, but it's not far off. best thing to do is to talk to a competent trans builder such as roseller, jakes, flt, and they will be able to tell you exactly what needs done for your power level. in the end, a 4l80e that is built for 800 horsepower is going to have a much smaller parts upgrade list vs a 4l60 built for the same power.
Old Jul 9, 2015 | 12:11 PM
jcob's Avatar
Thanks for all the input, looks like Its going to be an 80. I am going to order jakes stage 2 rebuild kit with an had forward hub and a billet input shaft. I'm also thinking of ordering this shift kit http://m.summitracing.com/parts/trg-4l80e-hd2/media/images
Old Jul 9, 2015 | 12:36 PM
GMCSIERRA5.3's Avatar
with the jakes kit you dont need a shiftkit it will tell you how to do your own hydraulic mods
Old Jul 9, 2015 | 04:25 PM
jcob's Avatar
Ok thanks for that info. Saves a little more money
Old Jul 9, 2015 | 10:14 PM
mrvedit's Avatar
Moderator
Originally Posted by jcob
... I am going to order jakes stage 2 rebuild kit with an had forward hub and a billet input shaft.
That is exactly what you need; IMHO the billet input shaft is a must.
As mentioned you don't need any other shift kit. Get everything from Jakes Performance.
