Choosing a torque converter
Car has a 3.42 gear, 335whp, 345tq and I don't drive it often so it doesn't have to have great street manners. It's just a car I like to play around in.
I'll be putting a bigger better engine in eventually but will likely end up going with a different tranny at that point so I'd like to stick with something relatively inexpensive.
Any advice would be appreciated
I see nothing he put needing step in. Ryan called him "that guy" so he typed up a retort.
Anyways Op I would hit up Circle D
At the end of the day I wouldn't waste my time on a 2800 stall let alone a 3600 personally if I was into performance. the stock Fbody stall is 1700 and a 2800 would be unnoticeable jump. Not that he has an Fbody stock converter preset but using as reference.
I had a SS3600 and got it because many said a 4000+ was too much for the street. I regretted it after a few days. I now have a Circle D 2e 4200 stall. Good luck
I prefer modest stall speeds because I like very civil street driving. While a 2800 stall would be a modest improvement for a completely stock engine, considering the expense of buying it and effort of installing it, it really doesn't make sense unless you are already replacing the trans and what a near-stock converter. And after adding some bolt-ons and definitely after adding a cam, you will want a higher stall. So, even I would suggest a 3200 for very civil street driving, and a 3600 might be preferred. Just stay away from the cheap 3600 TCI as that was annoyingly loose on the street.
No one here has ever posted that they bought a quality converter and it wasn't worth it.
However, there are zillions of posts by people saying that after they bought a quality converter that they regretted having wasted money on a cheap converter.
If you can't afford a quality converter now, save your money until you can.
:g ay:
